EricMichael
k guys freind just picked up an 05 fusion 900 today..144 carbide studs stock, hows he going to do against my properly set up slp viper/v-force reeds 192 chisel studs??
dude, fusions are slow. i think you could beat him with a 700 SXR
those sleds are pathetic
sxviper32
what he said ^^^^ polaris guys even make fun of them...
you might want to call your friend after the winter is over when he is done grabbing his ankles
You can make them run if you get rid of the restricted air box in those things and do some clutching.Between the air box and exhaust to meet emisions it just choked that motor right out.
yamahajunkie
give your friend a number of a good dentist and a bottle of loc tight. those things are rattle traps.
vipertripplexxx
LMAO!!!!!you might want to call your friend after the winter is over when he is done grabbing his ankles
Yea those confusions are sick er something???
I raced a friends 05 fusion, with my slp triple 02 viper this last vinter.. We where dead even from 0-140km/h, uphills.. This was in a very good ski slope..
He had slp single pipe on his as well.. And a 44mm track.. (i`ve got a 38mm track)..
nodoo_s
fusions are a little slow for a 900 stock,but like it has been said on another thread, a little tuning and they will run pretty fast. a piped viper should be a close race but i would bet mostly on the viper but it should be close.
all you fusion bashers are going to eat your words when you find yourself behind a properly set up liberty 900. Yes they are slow stock, but it doesnt take much $$ or effort to make them scream. SLP sells a single pipe and airbox setup that will have you grabbin your ankles to the beat of 160hp. another pipe is available from SLP for the 06's that puts it at 165hp.
http://www.startinglineproducts.com...&view=dyno&catalogID=3&catID=19&productID=621
not worried about the fusion no matter what
my SRX has close to 160 HP now on pump gas after being ported and set up properly.
in fact, i beat a fusion January 2005 at the snow drags not once but twice and it was set up good. dont get me wrong, it would be a tight race if the fusion is set-up properly but with a 700 i can run right with it if not out run it with better fuel mileage too
vipertripplexxx
Yo BBlue,
I saw a 600 HO run with a Fusion, soooo talk to the hand!
Any sled thats been modified with pipes, and properly tuned is probably not going to be a dog.
As for 165 hp out of a fusion.....well lets say SLP likes to inflate the numbers just a little. I'll bet your lucky to see 155.
Talk to a fusion owner...They will tell you whats up!
vipertripplexxx said:Any sled thats been modified with pipes, and properly tuned is probably not going to be a dog.
Dont think you are ready to take on the world with your piped viper, but you are underestimating what 160ish HP is capable of doing. Your viper isn't a speed demon bone stock either. You are comparing apples to oranges with a piped viper vs. a bone stock fusion. Yeah it will get beat, obviously. you have $1000 in pipes on your motor. Put the same money in the Fusion and see what happens.
vipertripplexxx
BBrain,
Do you know someone with a fusion thats piped? Are you in the U.P.?
Let me know. I would be happy to race any fusion thats not a big bore.
Maybe we can hook-up on gogebic? Torch Lake?
Grand Rapids area, and you seem to be the only one argueing??? Sometimes ya just gotta suck it up and face the fact, a piped viper is not the top dogg on the snow. Once again you will one day realize what 165HP will do to your giant ego. Yes. my neighbor has an 06' with a re-flashed ECU. PORT your viper or srx and you won't get beat. I personally would never buy a Fusion, the liberty is a time bomb, but when they run they are one hell of a power plant and you can't blow them off like a Jaguar.
vipertripplexxx
EricMichael said:k guys freind just picked up an 05 fusion 900 today..144 carbide studs stock, hows he going to do against my properly set up slp viper/v-force reeds 192 chisel studs??
The original post above.......144 studs, other than that it's stock.
ANSWER TO QUESTION......YOU WILL SMOKE HIM LIKE A CHEAP CIGAR!!!
HUMmmmm?Sometimes ya just gotta suck it up and face the fact, a piped viper is not the top dogg on the snow.
Reaalllly, is that a fact?Once again you will one day realize what 165HP will do to your giant ego.
I don't feel too bad when it takes 900 POS to beat a 700 yami.
Blue_Blooded
is it just me or didn't polaris stop making the 900? maybe there is somthing behind it. i also have seen one too many of them on fire on the net. whats up with that?
Maybe This Is Why!!! Lol
the 3 letters after the 900 says it all
vipertripplexxx said:Reaalllly, is that a fact?
