Bar Riser Set-up for Viper
Viper Treats
Appleton, WI
Just finished up the bar riser on my wife's viper. I know there have been lots of questions on this topic, so here is my set-up. This is a very clean set-up and you could probably go with a taller spacer block than what I did. The new cables are plenty long.
Riser:
Power Madd Pivot Adapter Kit: Power Madd # 15583
Dennis Kirk #592891- $47.99
Power Madd 2” Pivot Style Block: Power Madd # 15539
Dennis Kirk #292883 – $28.99
Vendor: Dennis Kirk
Comments: Has all fasteners needed in the kit, good instructions included.
Brake Line:
Exented Brake Line for Viper: Part #WP40-0019 - $50.00
Vendor: Jazz Motor Sports
Comments: Cable is 4” longer than stock. Has stock type banjo fitting. SS Braided line for better brake feel than stock.
Cables:
Throttle and Oil Pump Cables from 03 MountainViper
Throttle Cable Part # 8EN-26311-00-00 - $20.00
Oil Pump Cable Part # 8EN-26320-00-00 - $22.00
Vendor: Local Yamaha Dealer
Comments: Cables are 2+” longer than std viper.
looks good.you should have called me i'm 20 min. from you and could have saved you money.i stock all that stuff.as far as height you can go up to 5" rise with the cable's you have.we should ride this winter or come up on the trips we do.
Hey Man, where are you located? I am in Dar Boy (Appleton) always good to know some other riders. Maybe truck pool, save some $$ gas. I will keep you in mind if I need some other parts. I thought the cables were resonable from Yamaha, surprisingly. Looks like you have an aftermarket suspension in your sled. Any hints on installing a SC-10 III in my Viper. So far I have the suspension, working on putting it back together, have dimensions from a rev, that is as far as I am.
