Viper Treats
I installed a mountain viper oil pump cable for a bar riser set-up. I measured
1-13/16" for the cable adjustment on the old cable before I took it off. I can't get that much out of the new cable, so I basically adjusted it so when it is at full throttle the oil pump seems to be actuated wide open. Looks to be around 1". Is this OK or doesn't someone have a better measurement for me? Maybe I measured something wrong before.
Thanks,
VT
Thanks,
VT
Check the spec on the tech pages, I can't remember it off hand.
richierich
its 20-22 mm gap.
Viper Treats
OK thanks I will check it.
I will be needing some studs and a riser block for my new Rev (1.25" lug) I am picking up this fall. I will get some prices from you this fall.
richierich
no prob. let me know.
sifton
Hey Rich.....
Rich- see my post please.
