seanmurphy26
where can i buy skid bushings for a 98 sx online? maxx perf used to have the kits but...no more of them
also when i take the skid off should i replace the bearing on the drive shaft? thanks.
richierich
i can sell you all the bushings.they would be $67 shipped.you dont need to pull driveshaft to replace suspension bushings.i guess thats up to you if you want the extra work to pull chaincase and drive shaft.the bearing is $20.i only change them when i do a track swap since its apart already.
