Crank and cases
theblues
Ottawa
03 viper std, no mods.... Blew a centre piston and just did the teardown.... mag side seal blew and noticed that the mag side bearing was not as free as the others....cleaned bearing and installed it just seems a little looser than the others....Is this normal when that side seal goes or is it the normal play...
Any input would be great, thnks.
daman said:
keep us posted :)
What I did was wash everything out and re-lubed the bearings and the difference is extremely small, no noise, no drag, same resistance. I can feel a slight play cause I played around with engines but two of my sled bud's tried things out and did not notice any play in either bearings. Then I again washed everything up and there is a noticable noise difference in the mag side to the pto side but so did the new one I tried out.... from what I have experienced, most new bearings make noise until they are lubed up... It's not that I'm cheap but I did read about a post and this guy replaced both end bearings with inner races pressed on and they were almost the same as his older one. I think he spent over $200 for the job. Just can't afford to throw money away.... what do you think...thnks
Hmmm...sounds good,make shure your oil pump is within specs run
a little premix at first and she may be good to go.
good luck ;)!
good luck ;)!
I was thinking of making the fuel screw fat ( 1-7/8 to 2 ) turns and re-adjust the oil rich and mix my first tank with one qrt oil...how's this sound after the tank is gone re set fuel to specs and oil cable then do the plug burn test with new plugs low-mid and hi range shut down and pull the plugs each time and see how it looks....What do you think...thnks
don't run her over rich tho,,keep an eye on thoes plugs and wash man!!!
Everything is all cleaned up and ready for the new parts...parts on order will post back progress...
Pics
here is some pics of the burnt piston
Redsnake3 thanks anyways, I have all replacement parts just waiting on seals and a base gasket to put it all together…I will keep you in mind though, I may buy an extra jug and piston as a spare…How much$$$…Also if you have any tips/hints to offer before I reassemble it would be appreciated…It’s a standard rebuild no mods. I’m passing this sled to my 15yr old son this year…
Aj; that sled looks cool been following your build. I have a spare hood and I'm thinking of having a few cool skulls - blues and whites airbrushed on over the front and spiderwebs suspending the viper logo on the sides. I think my kid is gonna like that... :letitsnow
Sounds Nice man. Thats a Project for yah on your spare time..See i only did this was to be kinda *orginal* i hate having something that other ppl has. that is why i went with pipes, and a cool new look. i want to be different, i want to stand out ya kno?
And your Design sounds freakin cool i hope to see you get into it:) its quite the project! To me its all worth it in the end man : )
Pic's
Here are just a few pics of cleaned up cases and crank.
Getting her back together
Just finished the rebuild and cleaned the engine bay up...
Torque limiter
Installing the engine limiter
Engine in
Just a few pics of what goes on...
Clutches and engine alignment...
