Chris
Hey guys i knoe its not a real big thing but i am desperately looking For a throttle cable for my exciter butter fly carbs realy need befor winter . . . if you guys could help me out that would be great its for my vintage racer its a 78 exciter 440 only thing i need is a throttle cable for the 87 eciter carbs i tried to for new but they dont make them any more
killerklown
I have some for a late 80's Vmax 540, if they are the same let me know.
Brad_69
Chris,
You can go with a used one, but you should buy a new one. They are only around $20 or so. Engine looks great. You should also keep that engine shroud on. It will aid in the cooling of the engine. The PTO side will over heat and burn up. Brad
Chris
Ya i have to get a shoud . ..i think the previos owner burnt it up b4 ( new head) There is no cable available threw yamaha or aftermarket
Brad_69
Those are Phazer carbs, right? If so just get a Phazer throttle cable. I have several engine shrouds. Brad
Chris
Nope exciter 570 carbs i gues not many years had the butterflys and how much for they shroud ? i am located in ontario canada so if you could ship it COD that would be great
Brad_69
Sorry, I don't ship COD. $10 US dollars (international money order), and and another $10.00 US dollars for shipping. You should use a Exciter throttle cable for that year. I think the butterfly carbs on the 570 Exciters were for only one year. Brad
nightmanx1
You need to be carefull on the cable. My 1987 Exciter has round slide carbs from the factory. Make sure you get the right cable.
Chris
its a deal brad its some thing i need . . . if i could get your address ill send out a 20 dollar US money order plus can you through in the nuts and bolts and any thing you need to mount it .
Thanx
Thanx
Brad_69
I always replace the screws, because the heads get stripped. I will look for more screws for you. I would have to hear that you blew up that engine just because of the cheap little tin shroud. MY address is
Brad LaDuke
142 Clinton, St.
Redford, NY 12978
Brad LaDuke
142 Clinton, St.
Redford, NY 12978
Chris
Ya ive been looking for one . . .No luck finding one any where arround here i knew i needed to get one . . . ill send that order out later today or tomarow. And my address will be with it .
