Bored this summer
jimmie d
North Port, Florida
Added a few more mods to the Blue Viper. Perfect partner to VX7R, M10 vs Expert X. The rope pull, clutch guard, rear handle and arm caps were all done with Duplicolor Metal Cast
Jim
What about the bar riser? I'm looking for one in that style, I'd go with the Roxs riser but I dont like the way it looks. Let me know. Thanks
whats adhesion promotor? Jimmie like a primer? preper?
Pat
Not sure about adding pipes.The VX7R is really clutched great and with the 1.5" 136 track and Expert X will put you on your back out of the hole.
The Adhesion Promotor is a clear primer that you put on two coats, 2 minutes apart than the first coat of blue 2 minutes later. Go to the duplicolor site they have all the info. Gives a great annodized look on metal that has a shine, not that great on rear bar as I could not get much of a shine on it stock.
Jim
