Gordy
2000 SRX, I need the center to center distance of the upper and lower radius rods, and also the tie rods. this info would help alot. thanks in advance. GORDY
Hi Gordy: I think I can help ya out here buddy.
Control arms:
Upper 460.2mm +/- 0.5mm (18.118 +/- 0.0197 in)
Lower 458.7mm +/- 0.5mm (18.059 +/- 0.0197 in)
No spec is given for the tie rods, but if you line up the punch mark on the top of the spindle, and the one on the steering arm, you will set the tie rod length when adjusting your toe in/out. Toe out should be about 1/2"
Camber should be 0*
Control arms:
Camber should be 0*
Gordy
thankyou very much. now i can put my freshly painted suspension back on. GORDY
