1.4" Track on Viper
Homer
Minnesota
One more question guys - can a 1.4" track be run on a Viper? Will I have to remove the tunnel & heat exchanger protectors?
yes, yes and yes. to remove the heat exchanger protectors, cut the lower welds, stick a screwdriver in them and wiggle until the upper weld breaks. trying to cut the top welds is tough and the welds break a lot cleaner than you would think!
I ran a 1.4 that was notched off of a ski doo, and I ran 8 th drives, and left everything else sock. Maxdlx
