2002 viper
- Aug 7, 2006
We have about 1000 to spend on the sled.. i am looking for used pipes and 3 k&N filters to get rid of the air box and rejet it. How much Hp will this make and if any body has some used K&N filters or Pipes drop a PM for me
aSRX600guy
Keep the airbox, the pods will have you sucking hot air, especialy off the start.
2002 viper
- Aug 7, 2006
So you are saying the K&N filter will not help me??aSRX600guy said:Keep the airbox, the pods will have you sucking hot air, especialy off the start.
ViperTom
The K&N's will just cause you problems...not worth the effort. Depending on the pipes you put on you should see 145 hp. to about 152 hp. Be patient and you will find someone selling pipes, jets and clutch kit for $4-500. Make sure you install a Bender Opticool headgasket and a rear heat exchanger as well or you will smoke your motor.
Tom
Tom
