I removed the butterfly carb and am currently runing a mikuni 36mm single carb on it. It is stock porting and clutchung right now. Is this too small. should I use a 40mm? I'm gonna run the sled in a vintage drag 360 feet only. Any recommendations. Will a 40 mm be to big? The 36mm is a vm type carb and seems to run alright once I get the jetting sorted out.
Should I go to 40mm?
All imput is greatly welcomed.
John
John
AHood
what you should do is buy a set of billet aluminum reed stuffer carb adapters from me and bolt on twin 38 mm carbs. i have details and pics if your interested.
