02 viper skid on 99 sx
It will bolt in but you should also long travel the front cus the skid geometry will be wacked.
yes it will bolt right in and you can do as Turk said and long travel the front by just getting the longer shocks from a viper/sxr etc. OR if for some reason you dont want to buy the longer shocks Hauck has a set of extensions that you can use to gain more ride height on the front end.
Thank you guys, well that was my next question, I have the front shocks and all ( i guess) radius rods (no ends) do I have to get them I supossed, steering rods and sway bar....now any of you guys did it ? I don't know where to start...Any help will be great....
Here is the hole story. I bought the shocks last year and at haydays I found the rods and steering rods and sway bar all for viper....the radius rods don't have any ends on them, I mean the eye on one side and the threads on the other side....Where do I start now. My old shocks are gone and I have no clue how to start the swap of the rods and all that.....
Also I had the shocks of a viper for the back, order limiter straps and they are the same ones I had.....same part number and all..... :dunno: I send my skid to the welder because my w arm was crack and the bar where the small shock attach on the bottom was crack and one rail was crack...He wants $100 to do it but I'm looking at a complete viper skid......on ebay
Thanks guys for any info ;)!
Stealth800 has a viper skid for sale on here.
http://www.totallyamaha.com/snowmobiles/aaTECH/Ski_Alignment/Ski_Alignment2.htm
There is a good write up there on front ends.
It is really just a matter of swapping rods and readjusting camber, toe-in/out when you are done. You will need spacers for the sway bar links if you are going wider. You can see the spacers I have in this pic. You can get rod ends lots of places, dealer or aftermarket, or from someone here I'm sure.
Ok Looks good on the pic thanks, but the radius rods I have on my sled now the seem like they are the same lenght than the ones I have from that viper, also they are like backwards, the ends are inside instead of on the trailing arm.....The rods must be longer or the srew on ends will fix that....Thanks in advance
