In the Clutching Specs area of TY, Turk has some specs for Vipers: "53-43 helix, green spring everything else stock"
Anyone know the manufacturer of the helix he was referring to? I understand helixes vary quite a bit from one manufacturer to another even with the same angles.
Also, "everthing else stock" I assume that means stock hole position for the green spring - anyone know for sure?
I was refering to a Dalton helix. You can also use a 48/40 advant-edge helix. Also some sleds can use the red at 80 wrap & get good results & soom need a green at 60 in the secondary. Keep the primary set up stock.
