Phaser II -suspension help
uperjim
Does ayone know if the slide rails are interchangeable between original phasers and phaser II,s. Also what changed on the 98 phasers. Anyone try and put an Exciter suspension under a PhaserII? my phaser II suspension needs allot of $ dumped into it and I am wondering if there is a better option---trying to upgrade at the same time. thanks!!
I have several suspensions for around that year. Can you send me a picture of your suspension. I will see if in fact I do have one. $45.00 plus shipping. Brad
Brad---A pic at this point won't show much---it is totally disassembled. We are putting a new 1 1/2" 121" ripsaw track on and have to make a decision soon if we are going to try something different. The suspension is currently totally stock----the rails can be salvaged but the previous owner ran for awhile with worn hyfax and the alum is shaved down about 1/4 ' at the beginning of the curve.I am not too keen on drilling new holes in the tunnel for a different setup unless there is a template or something accurate to use.
The rails are shorter on the original Phazer, but if you have a set, they can be cut off and the rear peice of the Phazer II rails welded on.
As shown by Brad's post, used Phazer parts are plentiful and can usually be found reasonably priced.
I don't think much changed on the 98 Phazer versus the 97.
Anyone with a complete Phazer II skid in good shape-need to turn a project sled kinda quickly and need a skid for it. Also a complete seat.
