Help Installing Power Inc. Pipes
Nicko
Argentino Loco
Mound, Minnesota
I bought them at haydays and I'm getting ready to install them....Never did this before, my buddy runs cats and he thinks he knows everything, but I don't want to screw up.
I have all the jetting/cluthching info from pro 116 (thanks for all the help you been giving me ;)! )
Anyways the installation, wich one goes first where they go....should I put the end first on the jugs and the the pipes or :dunno:
Also I saw that they have some red stuff on some places...I'm assuming is that red high heat silicone.....where should I put that...i saw a ZRT one time with some red stuff on all the springs, is that something I should do....?
They are the center dumps.....i guess.
Any help guys will be awesome.....Pictures if is not a pain will help to.....
HP increase...? My sled is a 99 sx 600.
I'm not into racing or anything but I will love to kick my buddys new IQ 600 and ZL 600 at least ones this season....Maybe it will be hard......
Go to the tech section. Scroll down to engine/ clutching section. Near the end there are instructions for installing your pipes. The red stuff is hi heat permatex silicone which helps seal the pipes at the joints. Also putting it on the springs reduces vibration which makes em last longer. Make sure you don,t run those pipes over 8200 rpm......they like 7900-8100 rpm at wide open throttle.
