1988 Yamaha Inviter wiring diagram?
rs2
Twin Cities, MN
I need a wiring diagram for a 1988 Yamaha Inviter. There is a problem with the wiring to the throttle switch or some component in the wiring.
The sled will not run unless the pin in the throttle lever is pushed up into the throttle switch. Bypassing doesn't work or have any affect on the behavior. Both switches seem are working and check out. Throttle cable is adjusted correctly.
Anyone have an idea what the problem could be?
Can anyone post a copy of a 1988 Yamaha Inviter wiring diagram?
