freefallin700
- Aug 14, 2005
I have a 2002 mm700 wil v-force 3, peak head,bender triple pipes, reed spacers,and k&n filters. I need help with the clutching and gearing in the sled. I would like to achive a nice trail setup. I am at about 0-2000 ft above sea level. Thanks!
Your gearing is pretty low right now; might see 85 mph...90 on a good day. You need a lot steeper helix & more aggressive weights. If I rember(had same sled similar set up) I needed about a 51/43 helix(I got one For sale) with stock weights loaded to the nutz! I changed to 9 tooth drivers with a 1.1" track & saw about 100ish mph. $65 US shipped for the 51/43 helix.
