hereismylife
hello again,
I was told the sled I got was stock no carb tuning but here is what I found..
I am tring to get my sled carb figured out. here is where my carbs are at
mains 141.3 143.8 143.8
pilot 45
needles 6dgm5 6dgm5 6dgm5
clip 2
air 1 1/2
I was reading the specs ( factory setting) and this is what i found out.????
mains 145 143.8 143.8
pilot 45
needles q8 q4 q4
clip 3
air 1 1/2
my question is why do I have the same needles and what does 6DGM5 stand for and WHY ARE THEY ALL THE SAME?????
also why is this setup this way???
anybody help me out so I can get this machine back together tonight....
thanks again joe
pilot 45
clip 2
air 1 1/2
pilot 45
needles q8 q4 q4
clip 3
air 1 1/2
thanks again joe
if you go under the tech page it show's you exactly all the specs on your sled go under stock specifications
hereismylife
Yes that is where I got these numbers at that I posted.
The problem is they do not show this number 6DGM5 for the needle
thanks for the post and info though.
The mains should be #1 #2 #3j_k_auto said:hello again,
pilot 45
clip 2
air 1 1/2
pilot 45
needles q8 q4 q4
clip 3
air 1 1/2
thanks again joe
145 143.8 143.8 Stock
The Jet needles are and should be all the same.
The 6DGM05-3 is the size(dia) of the needle and the taper lengths at different distances on the needle itself- Hence they should all have the same needle...
Now the needle Jet (nozzles) are different #1 #2 #3
Q-8 Q-4 Q-4 Stock
The needle jet(Q-8, Q-4) is what the jet needle(6DGM05) rides in and has different diameters on the inside to regulate how much fuel passes the needle at different throttle positions.
T
P.S. Your jetting is staggered for the reason of one cylinder runs cooler than the other 2 so yamaha allowed the jetting to be leaner in the one cylinder to prevent plug fouling.
I ran the same main's for years. 143.8 141.3 141.3. Maybe it is a mistake but why would the mag side be a 141.3 and the other 2 143.8? that is completely backwards as the 143.8 is a fatter jet than 141.3 and the mag side requires the 1 fatter jet as it is the "hot" or lean side.
yamaholic22
on sx engines with a single pipe and SOME triple pipes the pto is the hot cylinder and is the one that gets the one size bigger main.
That is correct. Sorry but I am confusing myself hereyamaholic22 said:on sx engines with a single pipe and SOME triple pipes the pto is the hot cylinder and is the one that gets the one size bigger main.
BBlueSRX said:I ran the same main's for years. 143.8 141.3 141.3. Maybe it is a mistake but why would the mag side be a 141.3 and the other 2 143.8? that is completely backwards as the 143.8 is a fatter jet than 141.3 and the pto side requires the 1 fatter jet as it is the "hot" or lean side.
Duh, You are correct! I had my facts backwards. I don't know what I was thinking, musta been tired. T
