I did some drawings on Microsoft Paint, the dimensions are 467 x 435. But the size is 596 kb which is too big to download on TY. Is there a way to lower the kb without shrinking the diminsions?
Sorry, but Im not the most Puter literate!!
LFM
- Feb 17, 2004
- Vancouver/Whistler Canada
- www.mainstreetcorridor.com
you can email it to me and I can lower the kb without changing the dimensions
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
LFM , PM me your Email addy and I will send them. Or if you can give me some hints how to do it, I'll give it a try. Thanks
Shorty, I have pic resizer but I couldnt figure out how to just reduce the kb and not the dimensions of the drawings. I do use it for all my Pics though and it works great!Thanks, Sno-X
crewchief47
Lifetime Member
I think MSpaint uses bitmaps so converting to jpeg should accomplish the downsizing without affecting the overall dimensions. Unless of course you saved it as a jpeg?!?!?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
If you want so that you don't take up much space on this site, host the picture at www.imageshack.us and it will resize it for you automatically and you can set the size of the picture. Hope this helps.
It works, woo-hoo!! Thanks
shortstop20
- Mar 6, 2005
Sno-Xr said:Shorty, I have pic resizer but I couldnt figure out how to just reduce the kb and not the dimensions of the drawings. I do use it for all my Pics though and it works great!Thanks, Sno-X
It does not allow you to choose KB size because the program doesn't know if you want the picture 200x100 pixels or 100x200 pixels which would be the same amount of KB. 200x100 is just an example. If you size down the dimensions and then check the properties of the file you will be able to see the physical size in KB of the file.
The pics are small already.shortstop20 said:It does not allow you to choose KB size because the program doesn't know if you want the picture 200x100 pixels or 100x200 pixels which would be the same amount of KB. 200x100 is just an example. If you size down the dimensions and then check the properties of the file you will be able to see the physical size in KB of the file.
When I look at the Properties and it shows the dimensions 467 x 435 @ 596kb but photos I have are are 800 x 600 @ only 82kb. What makes the kb's so high on the smaller dimensions and not the one with larger dimensions?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
No problem, that is what I am here for!Sno-Xr said:It works, woo-hoo!! Thanks
crewchief47
Lifetime Member
Sno-Xr said:The pics are small already.
That picture you posted is png. I'm no expert on image file types but I do know that the net prefers jpg because it compresses into a smaller file kb wise.
First image is a jpeg: 18kb
Second is a gif: 42.4
The png version is 37.1kb but it wouldn't let me post a png file that big.
All three are 287x287
redsnake3
you can see the difference in quality between the first and second.
shortstop20
- Mar 6, 2005
Like crewchief said, different file types have different compression characteristics. Jpeg is the preferred format on the internet because of it's small size. It's quality isn't quite as good, but it's still sufficient.
