Hey guy's!
I've read more and more of you guys with rod bearings blowing and ending up with holes in your crankcase! Is this starting to be a common problem with yamaha 4 strokes. I haven't even picked up my 04 warrior yet but I'm starting to have second thoughts! Should I be worried about this or is this only happening to sleds with heavy mod's? Please reassure me as I finally switched to Yamaha in hopes of reliabilty!
Rob ( Ontario, Canada)
redsnake3
to my knowledge this is only happenin when people arent changing there oil often enough and also getting water in the oil.
n2oiroc
it happens, but nearly as often as a 2 stroke blowing up. i have heard of a few rod bolts loosening and rods breaking. no matter how good the motor is they are still made by humans and mistakes happen.
jimmie d
Why are you asking thjis pn the 2 stroke side?
Jim
Jim
jr_amsoil
one of my buddies had the rod blow and its sittin in a pile now but it happens
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
jr_amsoil said:one of my buddies had the rod blow and its sittin in a pile now but it happens![]()
Knocked a good size hole in the block behind the starter as well. Motor had less than 1500 miles on it. All stock 2003 RX-1. Seems to me that most of the sleds having rod issues are 2003's.
Was this an '03 or newer?
shortstop20
- Mar 6, 2005
It was/is a 2003 RX-1. Me and jr_amsoil are talking about the same sled. We're friends.
Hey Short STOP20, any pre-cautions that you would recommend for me as I just bought an '04Warrior. I don't want to, I mean CAN't afford to fix this if it happens to me. This type of repair must cost a fortune to fix on these sleds!
Any suggestion would be appreciated!
Thanks!
Thanks!
shortstop20
- Mar 6, 2005
I'd help you if I knew what caused it but I don't know. I don't think very many of them are throwing rods, but I do feel there's a few more blowing them than there should be.
cacsrx1
shortstop20 said:I'd help you if I knew what caused it but I don't know. I don't think very many of them are throwing rods, but I do feel there's a few more blowing them than there should be.
The guy that had this one blow up heard it making noise for awhile before it let go, but kept riding it.
Mine went because of water (moisture in the oil tank). I didnt change it within the 300 miles I owned it. Leason learned.
Only noise was detination.
shortstop20
- Mar 6, 2005
cacsrx1 said:The guy that had this one blow up heard it making noise for awhile before it let go, but kept riding it.![]()
I know for a fact it had been hot before and low on oil. A little regular servicing goes along way in my book. Just because they are 4 strokes doesnt mean they are indestructable.
I told him that I would park it if it was me, but what can you do?
cacsrx1
Brand new first time out,( no miles ) we took it up north to ride the lakes. Warmed it up untill it shut itself off. 2 Years ago out in the snowies, oil level light came on but kept riding it. Those are the times that I know of.
jr_amsoil
didnt know about the that in the snowies. yea when we were in the hills he should have parked it. better yet find a cliffcacsrx1 said:Brand new first time out,( no miles ) we took it up north to ride the lakes. Warmed it up untill it shut itself off. 2 Years ago out in the snowies, oil level light came on but kept riding it. Those are the times that I know of.
shortstop20
- Mar 6, 2005
