What wuld you do?
What would you do?
  • 2000 for $2500.00
    Votes: 26 52.0%
  • 1998 BB for $3000.00
    Votes: 24 48.0%
  • Total voters
    50
Maddogs700srx
NH
I am looking to add another srx to the fleet. It will mostley be a trail and laker. I have two sleds that I am trying to decide over. On is a clean 98 woth a Bender 835 kit, pipes, and a electronic temp gauge set up. Its got a new track, ohlins, and is super clean. The other is a bone stock 2000 that is also real clean. Both are in the low 3000 mile range. the 00 is 2500.00 and the 98 is 3000.00.
The Bender 835 with big bore pipes makes 175 hp on pump fuel, with stock pipes around 165. The Bender cylinders are CNC ported with the 835. With exhaust temp gauges, new track, and ohlin's....I'd say the 98 would be the best deal IMO, but i'm just a troll, so don't listen too me!
Find out if has the big bore pipes, they are worth some cash!!!
Do a compression check before you buy!!!!!!!!!
i voted for the 2000 just because i think its more fun to "do it yourself"... i know that there is alot of valuable items on it but wat do i know... plus isnt the cank or something not as strong on the 98? just me.........
-dru
go for the 00, otherwise you are buying someone elses headache potentially. how do you know it was done right and then taken care of? more of a risk I think
i voted for the 2000.even thoguh it's not a steal on the sled but a nicer sled in genral.buy a big bore for the 2000 & have the added features of the 2000 as well.
I do know the 98 pretty well. The sled was built by Justin at Bender Racing. It has been maintained by another freind of mine. The sled miles are around 4500 and the BB has just a tick over 3500 miles. It has the Four window guage and the crank has been trued, welded, and balanced. He is running the stock carbs but is throwing in the larger bore carbs as well. It also comes with two complete sets of gaskets and two brand new pistons. However I also just tripped across a super charger for the warrior on the 4stroke side that sounds pretty tempting.
