Clutch alignment and center to center tools
Fleabags
Michigan
I had two major belt failures last year that nearly tore my clutches apart. One of them dented my footwell so bad that it made my foot sting for twenty minutes from the impact. At first, I thought that I blew a piston rod out the side of my block, it was so loud.
The second time the belt distroyed my speedo pickup housing and the cable ($100.00 + belt).
I tried tp check my clutch alignment without the proper tools and it seemed alright, however, I want to do it right.
Does anyone have a good set of center to center and alignment tools that I could rent off of them? I leave in Michigan and I could give someone a deposit while I use them. I can't see paying $100.00+ for a good Clutch alignment tool that I may only use once.
Does anyone have any advice, or feel like loaning me the tools?
Thanks,
