Power Valves
wiercj
MICHIGAN
As long as the projections of both valve housings are positioned to be on the same side, does it matter if they are orientated to the top or bottom?
I was cleaning mine (serviced prior by dealer) and believe to have put the first two on in the same orientation as I removed them (on top) and got to the third to discover that it was orientated on the bottom.
