redsoxrule
- Mar 1, 2006
OK..dumb question, hopefully someone has an answer. In reworking a 1994 Vmax 600 ST this fall, I removed the shroud to make things easier, removing the shroud stop cable. Now the thing is I can't remember where the cable attaches in the engine, I've got it attached now to the loop on the y pipe...there is also a single spring, I've got that running to the same clip on the y pipe back to the bolt that holds one of the stopper cables clip. If anyone has a VMAX from that time, could you take a look and see where the stuff connects....thanks.
