Regulator Output on the Viper?????
ExpertXViper
Livonia, MI
My Redline EGT needs to be hooked up to the regulator output on my sled for the power source. Where is this wire found and what color is it??????
Blue wire going across the steering gate should be good.
Right out of the Yamaha Tech Update manuals . . . (copied from an old post of mine)
Background:
The 300-watt electrical system uses different components than the 175-watt system. Technicians and customers need to be aware when installing electrical accessories on models with the 300-watt system.
Information:
When installing any electrical accessory, be sure to connect to the blue wire after the main Load Control Relay. This will ensure a regulated 12-volt DC power source that will not draw on the system until the load control relay closes.
etc.
Hey! ding there is a guy on here looking to loose weight and has a electric start that he wants to disable,maybe you can help with your electrical experience. (he's on general post).
