1994 V-Max 4 piston to cylinder clearance?.
kimoaj
Norway
Hi guys!
Tomorrow I`m tearing into a friends V-Max 4 engine, one piston is crushed. Skirts broken off, messy.
I`ve removed the head, when one of the pistons that arent crushed are at TDC, and I push it with a finger, I can easily rock it back and forth, seems to be WAY to much piston to cylinder clearance.
Therefor I wonder how much clearance there should be so that I can measure it tomorrow when I break it down.
I will make a worklog in the worklog section.
Joakim.
kimoaj said:
Hi guys!
Joakim.
ask here kimoaj these guy's know there sh*t!!!
Link
Hi guys ! Thanks:).
0.065mm, that is less then 1/10mm right?.
Today I tore the engine apart, measured the clearance on one piston/cylinder, 0.3mm!!.
Going to make a worklog now.. .
Thanks again!!
