So I finally got my helix I ordered from Advant-Edge. I ordered a 48/40.
I am running 8dn-20 weights with 4.5g rivets in both holes, w-w-w primary and green secondary per Mrviper700 and others. My question is the helix that showed up says CPR on it, and wondering it is indeed the right helix, and will it work with this set up, and at what twist? I presently have it at 3 on both the sheave and helix.Thanks for any input.
n2oiroc
that is an advant, just modified to cpr's specs for more secondary twist adjustment.
There will be a # stamped on the inside. Should be #3.
OK, I'll check that, thanks Turk.
3 & 3 sound right for twist?
