cyl removal
mulderdad
Beautiful British Columbia
Am I missing something?
I can't get my cyl's off. :o| #$%&* :o|
I Have everything removed ( heads,carbs,coolant drained etc...).
I have done everything but take a sledge to it. Tapped with a rubber mallet. But i'm nervous about hurting something. Is this normal?
Please help a frustrated guy out.
mul
There shouldn't be a problem then? Maybe those cylinders are just stuck on the base gaskets... I know even after the second time it was hard for me to get these SX cylinders off.
Sometime the alignment collers corode and get stuck on, try putting a good penetrating oil down around the top of the studs , let it seep down through the clearance hole on the cylinders.
