how to fill coolant, how much and what mixture.
Nicko
Argentino Loco
Mound, Minnesota
Any of you guys can give me a quick lesson on how to fill My 99 sx 600 triple with coolant.....from where should I do it, How much and what would be the mixture.....I just ad a 136 extension and drained the hole thing.....It was nasty anyways...What is the plug on the rear heat exchanger for....Air release..? Also is this rear heat exchanger a stock item or somebody add it onmy sled....I saw a lot of post here of guys talking to ad this to their viper adn other....They dont come with it or what...Just curiosity.....
Thanks in advance....
Hope winter gets here soon...... :brr
welll before you start make sure that the coolent that you have bought is aluminum friendly after you make sure it is remove the coolent cap and start adding untill coolent container is full then go to the bleed screw and open it( bleed screws are on the top of the tunnel on a srx. idk for sxr.) then bleed the system untill all air is out of the lines. tighten all screws and things should be done... ANYONE CORRECT ME IF I AM WRONG.
Ok I didn't bought yet......any specific brand you guys now.....? And what would be the right mixture coolant/water.
i use 50/50 in all the stuff around here. lawnmower, cars, sleds. i'm sure you could go more water in there to get better cooling, but thats what i use.
Follow the directions for mixing the anti-freeze that you buy. The freezing point actually drops with most anti-freeze if it's over mixed. (If you use too much water). You can buy a cheap meter (around $5.00) that measures the freezing point of mixed anti-freeze; you can get the meters at most auto parts stores or even Wal-mart.
You may also have a bleed screw on the thermostat housing. Sometimes you also need to lift the rear of the sled up a foot to help bleed the air out. There should be an article in the tech section on cooling system bleeding.
