The pilot jets are dirty. Take those carbs apart and clean them. Gotta pull the floatbowls off and remove the main jets and pilot jets and clean them good with carb cleaner and blow out the crud and varnish with compressed air. The pilots control the idle and small throttle openings, so when you aren't getting fuel in the low end and have to use choke to keep it running, that is the first place to look.
