Why is there different part numbers for a Venom and say a SRX or Viper? Don't these sleds have the same bulkhead? Anyways, Yamaha sells Venom protectors for 60.00 each and SX or VMAX protectors for 50.00 a pair. Who has a set of SX protectors and have tried to install them on a Venom? Does anybody know if this will work? THANKS
vipers have weld on style, srx/sx/have rivot on, some came rivoted on, some are made to install after the track is in, some are to be rivoted before.
i like the steel ones the best, the lower tab will slide easily between the bulkhead and the heat exchanger.
if you use the style that goes in with the track installed, pump a bunch of silicone or urethane around them before installing. this will keep them from vibrating loose
