seca
just going over my pre-season checks and did a comp. test. got 120lbs on all three jugs. took 6 pulls each to get it there. does this sound about right? sled has 7500 km. on it.
seca
anybody??
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Because not all compression gauges read the same in terms of pressure, you are basically looking for a consistancy across the board which it sounds like you have. If you are running equal PSI across the board, you should be good to go. I normally replace rings every 4000-5000 miles on these triples.
Also, dont forget to go through the power valves and clean them up. Engine sounds good though.
seca
thanks 2000srx!!
