NLViper
Just seen this Clutch kit used on ebay but it looks to be in good shape. Any body running one on there single piped Viper. As well does any body know what the specs were on the Helix and the springs.
Turk
TY TECH ADVISER
- May 2, 2003
That kit uses stock weights, green yammie secondary spring & an aftermarket primary spring. The helix will probably be close to a 52/44 by seeing what is in that kit & working backwards.
NLViper
Thanks for the reply Turk! Here is the link for the kit, it shows 48 gram weights (Is this what the Viper has stock?) and the guy said it was used for 3000 miles. Do you think it is a better set up than the one you told me about: Dalton 53/43 with Green Secondary?
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=300039408049&sspagename=ADME:L:RTQ:CA:1
