viperken
What is the stock gears that came with the Viper in 2002?
Which gear should I change for more speed?
Which gear to change for a better take off?
22 x 38 - 68l
Stock it won't quite pull it on top except in perfect conditions. So down on top gear may or may not gain speed. Likely not. (21 x 38 - 68l)
Another jump down on top will make it take off better (if you have traction) (20 x 38 -68l)
If you can really get good traction and don't care about top end dropping even more can really make them jump.
1badz
- Nov 19, 2005
Search, and came across this thread, so ....
I'm going to a 136 x 1.5 Intense. I was going to drop down 1 tooth to 21; will that be enough. I'm only trying to maintain the same pluck as stock at 121", but if I can use the same 68l chain for both 20 and 21 tooth upper, which gear will work best
..SNAKEBIT..
I think with the 136 the 20 top would be best if you are buying a gear.
there are tons of options when gearing
68 link chain
22-38=1.73
21-38=1.81
20-38=1.90
21-39=1.86
I am running out west a 19-41=2.16 with a 68 link chain WOW
they claim the larger the radius the chain bends the better
68 link chain
22-38=1.73
21-38=1.81
20-38=1.90
21-39=1.86
