Thinking of picking up a used 2001 SRX. I have a "good as new" 04 Viper ER skid. Would I get a better ride in the SRX by long traveling it or just dropping the Viper skid into it? How about the front end? I've got the stock front shocks from the Viper also. Should I upgrade the front end? Whats involved in the process?
I would just drop the Viper skid in but the front shocks wont work as the top of the shocks mount different... then that viper skid get put in, you will have to soften the spring and pull the limiter up some.
nhsrx701
- Jan 27, 2005
install that viper skid. then relocate the the front shocks mounts lower. hauck has shock mounts with multiple positions or guy on ebay has the brackets for sale or BeTheViper has mounts so you can use a front viper shock
http://www.hauckpowersportsinc.com/clearancedetails_1191_1.aspx
