BigMan76
General question here . . .
If I wanted to remove the graphics from the body panels of a sled, without damaging the underlying paint, how would I do it?
I am thinking about an early '90s Exciter project that I might want to replace the graphics; the paint is in good shape.
auji700triple
You can use a Heat gun, thats what i used. It worked Awesome.
NO PROBLEM 4 the TY Decal Blaster.
Any heat gun will work, I like this one because of it's adjustable heat range. Not to Cold & Not to Hott........Just Right
BTW.........It's a Steinel HL 1802E
Sorry I just tryed to down load pictures as they are just a tad too big, not sure how to down size them
richierich
if you dont have a heat gun a hair dryer also works just takes longer.if they is any glue left you can use go-gone.
or i also use depending on size and age of sticker a eraser wheel.its basically a big round eraser that you install on a drill and it rubs the sticker and glue away at once.on a old sled like that i'd try that since the sticker will probally crack and peel in little pieces making it take for ever.wheels can be found at a automotive store for under $20 and will last a long time.
blueblooded
^^^i also use a hair dryer.Like stated above it does take longer but you dont have to worry about blistering the paint like you can with a heat gun.
fastassyamaha
yeah i used a hair dryer works just as good, use goo-gone for the sticky stuff if any gets left behind
WD40 also works great for removing the sticky stuff.
G.B.
G.B.
auji700triple
i found that the hair dryer worked Really Bad. So i switched to my fathers HEat gun and it was easy as 1-2-3
