Bearit
Hi guys
I am looking at set of these for my viper and I wanted to know if anybody else has them or a opinion of them,I emailed them with some questions and I never got a reply,so could someone tell me do I need any other parts to use them like radius rods or are bolt on ready to go.Also I know that the mountain max trailling arms are shorter where the spindals go through but is the mounting and swaybar mount all in the same place,if I added to the spidal section could I use mountain max arms as I saw some for sale and it was a great deal.
Thanks Steve
Thanks Steve
They will come ready to go with all the needed hardware if you buy them new. I think all that comes with them is a spacer for the tunnel mount. You may end up replacing the plastic bushings for the spindle as they can be tough to get out. If you go with the MM arms, you will need to change the spindle and steering arms, everything else should bolt right up.
