n8sjh
I bought 2 1994 v-max 600 at the end of the snow last season. I took them out once and then put them in the garage. I did run stabil in them that is all. So what should I change as far as fluids,oils? Also what else should I look over. I know to look over track and replace studs and check hyfax and track tension. Anything else? Thanks
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
First thing I would do is clean the carbs. Check carbides for wear, change chaincase fluid, grease suspension, new spark plugs, fresh gas, top off oil. That's the main stuff.
