YAMAHIZAL700
Yeah, I was wondering the proper way of doing this, I have the basic understanding but any tricks of sorts?
See the Tech Pages on this site.
YAMAHIZAL700
Okay, thanks Ill do a search.
There is a separate link on the TY home page that takes you to a tech page area. Tech help stuff gets moved here.
follow bethevipers set up tips. it will handle way better than the stock set up as i found out last season.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
For toe in, toe out situations, if you can get yourself ahold of any material type piping that has a 5/8" OD and cut it 4 feet or longer and you put that between the spindals. Lines them up perfectly.
Viper_Jim
Hey check this site out!.....I refer to it all the time....tells you exactly what to do, as well theres tons of info about the rear suspension
http://hem.passagen.se/rogg/yamsetup/framv_eng03.htm
2ooosrx said:For toe in, toe out situations, if you can get yourself ahold of any material type piping that has a 5/8" OD and cut it 4 feet or longer and you put that between the spindals. Lines them up perfectly.
i have my sled set this way currently and no offence but the way betheviper tells you how to do it is a much better handling sled. i had it set his way for one weekend and the next weekend was set to yamaha spec. his way carves much better in the trails as i almost smoked a tree expecting it to turn as well as his with it at yamaha spec.
1badz
- Nov 19, 2005
Maim said:i have my sled set this way currently and no offence but the way betheviper tells you how to do it is a much better handling sled. i had it set his way for one weekend and the next weekend was set to yamaha spec. his way carves much better in the trails as i almost smoked a tree expecting it to turn as well as his with it at yamaha spec.
Why would you change it from betheviper's way???
i was concerned i didnt get it set right so i got the yamy dealer to set it to stock before i did our local yamafest. i could tell the diference in the 1st sharp turn. set the way it is though i can let my brother drive it as he weighs 50lb less than i do and my other siblings drinve it as well. so yamy settings on this sled are better in this instance.
