reed cage notch or spacers
Personally i like doing the reed stopper notch for two reasons. A: its free, which is always a good thing! B: It doesn't change the volume of the crankcase
do the reed notch to a set of viper/srx reeds. you will need to grind the inside of the case a little to make them fit in. larger surface area, better design and the stopper is set back further so when you notch it, it will be completely out of the way of the port.
also, while your in there, port your boots and stuffers. smooth everything together, there are alot of edges sticking up in there.
