yamaharider
 - Sep 2, 2003
I just purchased a 1994 vmax 600 with a 700 big bore in it and I  was wondering what would be a good clutch set up for 660' foot drag racing?(weights, springs, helix) any info would be helpful.
					you have a single pipe GYT or stock pipe
			yamaharider
 - Sep 2, 2003
I got two pipes with the sled, the guy said one was an aftermarket single pipe and the other was slp twin pipes.
					If you run the pipe I may have something you could try....
					try a 8ca w/ .8g in both holes, p-o-p primary spring, 45/39 helix with a pink ot wht sec spring .....jet 151.3 with needle clip in the 3 position with 1/2 shimmed.....this ran good on a 94 vmax with a gyt pipe.
