At the end of last season my buddies 2000 SRX started losing power almost as if it was missing, it wouldn't die but bog down and would barely move. Then it would be fine for a while and then repeat it over again. We bought a spark tester and are getting a really good spark so I think that rules out coils or CDI, but before we start tearing the whole thing apart I thought I'd check and see what you guys thought we should check. We also disconnected the TORS and no change. Any Ideas?????
does the headlight flicker while doing this?
Concept Carbon
T.o.r.s i would say but sense you disconected it, did you drain the gas and refill, maybe water in gas, i would do all the simple stuff first.
Would Dirty Powervalves cause this?
blue missile
i dont think so last year at service and aparently during the riding season prior i had a broken cable and a stuck valve. the sled ran fine only after fixing it did i notice a difference in performance.
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Wire rubbed through under motor?
jr_amsoil
mine kinda does the same thing but headlight doesnt flicker so i dont know for sure
