Exhaust Manifold removal
BlueRider17
Maine
What's the easiest way to remove the bolts from the exhaust manifold. I've found that the bolts under the manifold are tough to access. Anyone have any tips or tools that make this easier?
No easy way that I have found. The Mag and middle are somewhat easy to get off with a 1/4' drive socket wrnch with a 3" extension, but the two outside bolts, on the clutch side, are harder to get out. Just use a short 10mm wrench for those and you get about 1/4 turn each time. Hope this helps.
--Steve (O.C.)
