Srx clutching
norwegian
Well-known member
norway
Can I use 22/38 gearing with 8bu weights and a www spring or will it bog at start? What rivet combination do I need if I can? thanks
Gotta know what helix & secondary spring your using? Can,t even take an educated guess with out knowing that. Elevation would help. Won,t get ya bang on but should be able to get ya close. You wanna race or need some backshift. More info would help.
I have a 47/42 or a 51/43 avaiable. Want 50/50 on upshift and backshift but 30/70 either way goes too. Have a ripsaw 1,25 track. Rider weight approx 190 pounds. Green secondary spring. Want to play a little in powder. I have a hauck speed sheave too. www primary spring.
Very low elevation.
Run the 47/42. Use a .8 gram inner & a 3.6 gram outer. This is just to get you close. Nobody can get u 100% bang on & your gonna have to do some fine tuning but this is a good start. Run the green spring at 80 wrap.
Your taking a mish-mash of clutching parts & throwing em together. I can get you close. Run the sled; check rpm,s at wide open throttle & from there I can get you bang on.
Ya sorry for that, I haven't got that many clutching parts yet. Will do.
