SRX Pipes.
Try Bender,Power Inc End Dump pipes or SLP's. Aaen make less HP I am told.Aren't the triple pipes on an SRX the best for making the HP. Spending money on others might be a waste of time and money.Just my 2 cents.
On a stock motor, the only pipes that make HP are the PowerInc pipes, here is some reading material for you. They weigh in at 18 pounds less, I am going to change my main jets from 145 on 2/3 and 146.3 on 1 to 148.8 on 2/3 and 150 on 1. I will see how this jetting works out with these pipes and they sound nice too. Let me know if you have any other questions about them.
http://www.totallyamaha.net/forums/showthread.php?t=28052&highlight=Powerinc
It is not entirely true that the Power Inc's are the only pipes that make more power on a stock motor. The Power Inc. pipes are the only pipes that build more power at stock rpm. The Hauck pipes build quite a bit more power, but you have to spin the motor around 10K, and require a high RPM CDI. I have a set with CDI for sale, and will take $700 for both.
Sorry, I kinda combined both of his post about the pipes, on his other post he said about relability. Power Inc's keep the reliability and add HP.
BTW, when I take it out this year, I am going to run the clutching from last year and see how the RPM's fluctuate.
