Viper Help
m7freak
Oregon
Hi, I put a riser block (2") and sportech handguards on my brothers 04 mountain Viper. I had to do some trimming on his handlegrips and take apart the controls to get them to fit. I went to start it after and it will idle rough but cannot rev. It will just die if you rev it up. Plugs are not fouled. Any ideas what I could have messed up? TORS???
Throttle cable is too tight because of the riser being installed. Adjust the cable (loosen a little). It is triggering the TORS.
ok, i appreciate your help. I am heading out to the shop to check that out right now.
