EricMichael
Just wondering what you guys think, my buddy has an 03 xcr 800 and has htg pipes on it , my sled has slp pipes,v-force reeds,51/45 helix proper clutching and gearing (150lbs rider).. I could beat him on the grass in 500ft but he wants to go all out top end this winter...what kinda speeds does the viper pull with pipes?I just through the pipes on my sled last year without a tuned in clutch and worn out chisels and seen 129 on the dreammeter on hard packed trails..
better get yourself some 8dn-20 weights, g/w/g yamaha spring, your helix is ok and a grn secondary spring, stock gearing or 23/38 will be good
EricMichael
I haev the gwg spring, what would using a hauck orange do?What do people usually run in thier 8dn-20 weights
ExpertXViper
mrviper700 said:better get yourself some 8dn-20 weights, g/w/g yamaha spring, your helix is ok and a grn secondary spring, stock gearing or 23/38 will be good
MrViper whats the preload and total force of the g/w/g spring? Just wondering how it compares to my dalton spring.
x2ryder
Gwg 45 2.75 136
ExpertXViper
Thanks, ExpertX
taped throttle
8dn-20s - 4.5 in both is a good start, some like 3.7 in the tip.
