BlAdE
i have a 2001 SXR 500 and i had it out for a ride tonight and the lights are very dim even in the gauges and my tach dont work and my hand warmers dont either
also, she is really boggy on bottom end then cuts in and pulls good
what can i do to get a arm pull start? or raise the skis?
thanks
travis
thanks
travis
terret725
check the wires that go up to the gages and make sure they aren't melted from the pipe. also check the wires that go under the sled. if all theos are fine maybe the voltage regulators that on the back side plastic above the foot rest under ur pull cord. to pull the skis up get some adjustable transfer rods. or put a smaller shim on the top of ur transfer rods. also tighten the tension on teh center shock and put ur rear shock adjustment on soft. thats will transfer more weight to the rear and give u more traction and may bring up ur skis. but then again the 500 isnt the strongest motor so it maybe hard. also gear down a tooth on the top will give u more torque
Sounds like a short-cut. Check wires.
BlAdE
thanks guys ill have a look at it today
BTW if i drop one tooth what size chain will i need?
i dont need it to rise skis i just want a really good holeshot
see your other post. i made some recomendations for you.
BlAdE
i have checked all wireing and i have the thing scraped lol so what should i start doing to get it all working again all wire look good and are connected good
i am cleaning everything
im stumped i dont know what to look for now
Did you check under engine? Take out those ground wires from steering gate and clean.
ski
i would advise against dropping the gearing, for a better holeshot, adjust the secondary for the belt to sit higher in the sheaves at resting position, this will give you a lower gear off the line, you could also tighten the spring 10deg to keep it in lower gear longer. Make sure the springs and weights are in good shape and replace the springs if they have more than 4000 miles on them.
Just so you know, if you did drop one tooth on the sprockets, the same chain (68link) will still fit
nightmanx1
Look for wires that a mouse got into, that is what I had to do.
BlAdE
i cant sceem to find any bad wires and i have it scraped lol
anyone know what it will cost for a new stator ? only thing i can think is gone
Test all of your electrical components. There are specs for each one. I personally don't like replacing components that are perfectly fine. Testing narrows it down to the failed ocmponent so that you don't have to spend money needlessly.
BlAdE
thanks ill get it all checked out
