Gyt pipe info for a 95 vmax 600
Highmark
Hello, I just picked up a gyt pipe for a buddies 95 vmax 600 while I was at haydays.. I need jetting and clutching specs or even a phone number/website for gyt. I haven't had any luck searching on the internet.
Bend out the reed stoppers to 12mm, 8ab w/2.4g in the inner hole and 2.7g in the outer, p-p-p primary spring, 50/41 helix w/silver sec spring at 80 deg. #50 pilotsm, q8 nozzles, and 156.3 jetting, stock needle.
Thanks for the info, I forgot to mention this sled has a 144in track, and i'm not sure on gearing..How is this going to affect the setup you gave me?
Also could you tell me what jets I'll need for 8,000 ft and 6000ft?
Thanks alot!
Are you the same Highmark on the SW 4M?
Noope.. I wasn't in the creative mood when I signed up :roll:
what temp you want to jet for.....
Um..lets say 20 degrees
I have the specs for the GYT Twins, but not a single pipe. Do you have the single, or the twin pipes?
I'm assuming the single....
