312-617-0303 Thats my cell phone number its on 24/7...PLEASE replace ALL the gaskets.. I have a thing about re-using gaskets that have been already compressed!!!!!. It throws off the torque specs and doesn't do the rebuild ANY JUSTICE!!! The only thing you MAY NEED is the dial indicator to reset the timing.. i will send you mine IF you promise to send it back to me without destroying it!!!! The normal METRIC hand tool set, a few single edge razor blades and a BUNCH of cans of CRC brake cleaner... Use the red label NOT THE GREEN!!!! The red is trichlorethlyene (sorry about the spelling) and the green is some BAD/CHEAP paint thinner!!!!! A gasket set and a tube of YAMABOND. I forget the number, but go to Yamaha and ask the dealer Maybe Yamabond 5????? Keep away from that hi tack or copper coat stuff and replace the gaskets with NEW and MAKE SURE you follow the torque sequence!!!! If you have never went through a sled motor before,,,ask someone for the book!!!! I may have a book at home, I'd have to look... if you lived around Chicago i could teach you how to TWEEK the timing to BEAT all your friends,,, but you need EGT sensors in your exhaust and adjustable main jets to do that... The motors USUALLY don't last too long when you start advancing the timing and leaning them out!!!! But,, on the other hand,,, you will BEAT all your friends with the same sleds!!! (and beat them BAD TOO!!!!!) BUT,,, thats another story!!!! Gary Oles nosboy
